Posted September 10, 20231 yr As a thank you to your efforts re 2FA: I tell you some flaws in CWP control panel, so you can remove it 1. In the dashboard 1.1 in the firewall manager 1.1.1. sub control panel for CSF 1.1.1.1 In the blacklist configuration Press delete a permanent entry It says "Remove emporary entry" instead "Remove temporary enry" Actually it should say "Remove permanent entry" because those are permanent entries ----- 1.1.1.2 In the whitelist configuration Press delete a permanent entry It says "Remove emporary entry" instead "Remove temporary enry" Actually it should say "Remove permanent entry" because those are permanent entries ----- 1.1.1.3 In the temporary allow and deny Ip list configuration Press delete a temporary entry It says "Remove emporary entry" instead "Remove temporary enry" Actually it should say "Remove permanent entry" because those are permanent entries
September 12, 20231 yr Author Solution Corr: of course the temporary entries are temporary and not permanent, a copy paste error
