Posted August 23, 20231 yr Hello Sandeep, i have a sоme questions for this module: PageSpeed Module Has it been tested with CWP and if so, which module should be installed - Apache or Nginx (for Nginx & Varnish & Apache configuration)? Did you have experience and observation with this module? Do you recommend it? Thank you in advance and have a nice day!
August 26, 20231 yr Solution you should use it with Apache only as latest nginx is not compatible with pagespeed better to use script side js, css optimizer/plugin/module it will give you best performance
August 29, 20231 yr Author On 8/26/2023 at 12:19 PM, Sandeep B. said: you should use it with Apache only as latest nginx is not compatible with pagespeed better to use script side js, css optimizer/plugin/module it will give you best performance Thank you so much for your advice!
December 12, 20231 yr Hello, sorry but i didn't understand the solution, can you explain it with more steps.
December 12, 20231 yr 10 hours ago, Leebrimlow said: Hello, sorry but i didn't understand the solution, can you explain it with more steps. the solution is to use CMS side js and css optimizer you can use some minify plugin
