Posted August 18, 20231 yr I'm having a problem installing SSL Wildcard on my server Look at the two attached pictures. Is there an error in adding dns? Is there any note to solve the problem?
August 18, 20231 yr After _acme-challenge.clovstore.com add dot It should be : _acme-challenge.clovstore.com. Then restart the bind/named dns server
August 18, 20231 yr Author Thanks you bro , DNS has been restarted, I will wait for some time and re-apply the command in the shell
August 18, 20231 yr In this situation remove the domain name from the txt name record so it will look like: _acme-challenge After restart the dns server. Also you don't need to add A record for the _acme-challenge
August 18, 20231 yr Seems you've added the A record for acme remove that it is completely unnecessary. restart the dns server it will get started.
August 18, 20231 yr And regarding new line error Add a new line and save the dns record. Simply hit enter button at the end of the file to give new line.
