CSF (ConfigServer Security & Firewall) is a popular firewall and security tool for Linux servers. CSF is full featured firewall which contains many features and works on Linux out of the box. Its a Stateful Packet Inspection (SPI) firewall, Login/Intrusion Detection and Security application for Linux servers.
Here are some common commands that you can use with CSF:
Start CSF:
To start CSF, use the following command:
csf -s
you can also use systemctl to restart csf and lfd server
systemctl start csf lfd
Stop CSF:
To stop CSF, use the following command:
csf -x
systemctl stop csf lfd
Restart CSF:
To restart CSF, use the following command:
csf -r
systemctl restart csf lfd
Check CSF status:
To check the status of CSF, use the following command:
csf -status
Allow an IP address:
To allow an IP address through the firewall, use the following command:
csf -a
you can add the comment after the ip with space
example :
Quote
csf -a 1.1.1.1 allowed by admin
Unblock an IP address:
To unblock an IP address that has been blocked by CSF, use the following command:
csf -dr
Block an IP address:
To block an IP address, use the following command:
csf -d
example :
Quote
csf -d 1.1.1.1 blocked by admin
View blocked IP addresses:
To view a list of blocked IP addresses, use the following command:
csf -g
to find specific ip in blocked list use below command :
Quote
csf -g 1.1.1.1
Unblock all IP addresses:
To unblock all IP addresses that have been blocked by CSF, use the following command:
csf -df
Check for updates to csf but do not upgrade :
csf -c
To update CSF :
csf -u
To Force update :
csf -uf
Get an IP’s information country of origin & hostname/ptr :
csf -i IP
usage :
Quote
csf -i 1.1.1.1
Hope this helped and you can add your own commands below in the comment to help others.
  • Sandeep B. changed the title to Useful CSF firewall Commands list for System Admins
