Posted February 6Feb 6 Can i add an account domain1.com and then point domain2.com to the same folder.? So if i have a php file it says welcome to domain1 if i open it on domain1.com and it says domain2 if i open domain2.com?
February 8Feb 8 Solution Yes, you can.You will create the main account: User Accounts → New Account.For the additional domain, you will create that under the menu: Domains → Add Domain.That will ask you for the user, which you created above under User Account.Then you can either point to the root of the same directory, or a sub-folder.Or you can user Cloudflare to redirect the domain to another.
