Posted November 18, 2024Nov 18 There are lot’s of complains regarding the netdata not working or installing in CWP to fix the issue please follow the easy fix :you will need top install these dependencies before installing netdata from cwp :First uninstall netdata :/usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --forceInstall dependencies :yum install lz4-devel lz4 json-c-devel libuv-devel libuv --nobest yum install libyaml-develafter these depes are installed go to cwp admin » netdata » and install to from thereInstallation can take few time depending on your server performance.
November 19, 2024Nov 19 18 hours ago, Sandeep B. said:There are lot’s of complains regarding the netdata not working or installing in CWP to fix the issue please follow the easy fix :you will need top install these dependencies before installing netdata from cwp :First uninstall netdata :/usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --forceInstall dependencies :yum install lz4-devel lz4 json-c-devel libuv-devel libuv --nobest yum install libyaml-develafter these depes are installed go to cwp admin » netdata » and install to from thereInstallation can take few time depending on your server performance.Nothing happens, still caught in an endless loop, always keeps asking to install again.
November 19, 2024Nov 19 Author please try this /usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --force cd /usr/local/src rm -rf netdata git clone --recursive https://github.com/netdata/netdata cd netdata ./netdata-installer.sh --disable-cloud --dont-waitthen after the official version is installed without any error (keep an eye on errors if there is any) uninstall it again :/usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --forcethen install it from cwp
January 5Jan 5 I came here and followed these instructions:On 11/19/2024 at 2:46 AM, Sandeep B. said:please try this /usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --force cd /usr/local/src rm -rf netdata git clone --recursive https://github.com/netdata/netdata cd netdata ./netdata-installer.sh --disable-cloud --dont-waitthen after the official version is installed without any error (keep an eye on errors if there is any) uninstall it again :/usr/local/src/netdata/packaging/installer/netdata-uninstaller.sh --yes --forcethen install it from cwpThis aborted on me, so close though - Alma 8.10 with CWP The error message is “Package 'libuv', required by 'virtual:world', not found”I initiated the netdata install via cwp control panel. The install failed twice. I then found this “fix” or “workaround” here: https://forum.centos-webpanel.com/centos-8-problems/failed-install-last-version-netdata-in-cwp-control-web-pannel-centos-8-stream/msg48165/#msg48165 Then used the install script as found @ cwp —> “cd /scripts && cp install_netdata install_netdata.orig && wget -O install_netdata https://github.com/LPJon/cwpfixes/raw/main/install_netdata && /scripts/./install_netdata"The uninstall failed for this as well.The errors: -- Checking for module 'libuv'-- Package 'libuv', required by 'virtual:world', not foundCMake Error at /usr/share/cmake/Modules/FindPkgConfig.cmake:607 (message): A required package was not foundCall Stack (most recent call first): /usr/share/cmake/Modules/FindPkgConfig.cmake:829 (_pkg_check_modules_internal) CMakeLists.txt:2150 (pkg_check_modules)-- Configuring incomplete, errors occurred! FAILED '' ABORTED Failed to configure Netdata sources. ^ |.-. .-. .-. .-. .-. . netdata .-. .-. .-. .-. .-. .- | '-' '-' '-' '-' '-' '-' '-' '-' '-' '-' +----+-----+-----+-----+-----+-----+-----+-----+-----+-----+-----+-----+---> ABORTED Netdata failed to build for an unknown reason. Operating System: AlmaLinux 8.10 (Cerulean Leopard)CPE OS Name: cpe:/o:almalinux:almalinux:8::baseosKernel: Linux 4.18.0-553.33.1.el8_10.x86_64
