CWP Apache MPM Event Problem
I have a problem with apache MPM in CWP. MPM EVENT is constantly idle and apache is not responding to requests even though it is active.
I believe there is a problem with EVENT.
Solved by narin
  • Solution
On 8/11/2024 at 5:17 PM, Sandeep B. said:
did you increased the mpm connection limit and check ?
The problem was not caused by MPM itself. I solved the problem by activating the KEEPALIVE feature and setting the keepalivetimeout value to a low number; it works fine now.
Topics
