Posted July 10, 2024Jul 10 If you're getting this error and the repo is failing with Centos 7 with a similar message mentioned below then run the fix script to auto fix the base repo : Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was 14: curl#6 - "Could not resolve host: mirrorlist.centos.org; Name or service not known" Due to EOL the mirrorlist.centos.org doesn't exist anymore and removed you need to change the repo to vault.centos.org you need to run the below script on your server : curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash
July 11, 2024Jul 11 Before running this script, I just would run: sed -i 's/mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-* sed -i 's|#\s*baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-* Regards, Netino Edited July 11, 2024Jul 11 by Netino
July 17, 2024Jul 17 On 7/10/2024 at 4:50 PM, Sandeep B. said: If you're getting this error and the repo is failing with Centos 7 with a similar message mentioned below then run the fix script to auto fix the base repo : Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was 14: curl#6 - "Could not resolve host: mirrorlist.centos.org; Name or service not known" Due to EOL the mirrorlist.centos.org doesn't exist anymore and removed you need to change the repo to vault.centos.org you need to run the below script on your server : curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash Hi, kindly need your more description to run your bash please: curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash
July 17, 2024Jul 17 On 7/11/2024 at 3:42 AM, Netino said: Before running this script, I just would run: sed -i 's/mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-* sed -i 's|#\s*baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-* Regards, Netino Dear Netio please describe your bash? what is this for this bash? and what it will execute in the server??
July 18, 2024Jul 18 Author 9 hours ago, Navid said: Hi, kindly need your more description to run your bash please: curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash this is for repo fix of centos 7 only
July 19, 2024Jul 19 On 7/17/2024 at 1:02 PM, Navid said: Dear Netio please describe your bash? what is this for this bash? and what it will execute in the server?? These lines are just to make a small correction, due to the fact that the website 'mirror.centos.org' is no longer accessible. So I suggested a fix, to change the Centos7 repository addresses to 'vault.centos.org', which is still accessible. Edited July 19, 2024Jul 19 by Netino
July 19, 2024Jul 19 Thank you so much it's work perfectly, and it save me. thank you so much from both of your gentleman!
August 16, 2024Aug 16 On 7/10/2024 at 6:50 PM, Sandeep B. said: If you're getting this error and the repo is failing with Centos 7 with a similar message mentioned below then run the fix script to auto fix the base repo : Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was 14: curl#6 - "Could not resolve host: mirrorlist.centos.org; Name or service not known" Due to EOL the mirrorlist.centos.org doesn't exist anymore and removed you need to change the repo to vault.centos.org you need to run the below script on your server : curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash yum update Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was 14: curl#6 - "Could not resolve host: mirrorlist.centos.org; Unknown error" One of the configured repositories failed (Unknown), and yum doesn't have enough cached data to continue. At this point the only safe thing yum can do is fail. There are a few ways to work "fix" this: 1. Contact the upstream for the repository and get them to fix the problem. 2. Reconfigure the baseurl/etc. for the repository, to point to a working upstream. This is most often useful if you are using a newer distribution release than is supported by the repository (and the packages for the previous distribution release still work). 3. Run the command with the repository temporarily disabled yum --disablerepo=<repoid> ... 4. Disable the repository permanently, so yum won't use it by default. Yum will then just ignore the repository until you permanently enable it again or use --enablerepo for temporary usage: yum-config-manager --disable <repoid> or subscription-manager repos --disable=<repoid> 5. Configure the failing repository to be skipped, if it is unavailable. Note that yum will try to contact the repo. when it runs most commands, so will have to try and fail each time (and thus. yum will be be much slower). If it is a very temporary problem though, this is often a nice compromise: yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true Cannot find a valid baseurl for repo: base/7/x86_64 Hello, why do you think I am getting this error?
August 16, 2024Aug 16 Author YOU NEED TO RUN THE UPPER COMMANDS TO FIX IT it is because the repo are closed
August 16, 2024Aug 16 1 hour ago, Sandeep B. said: BUNU DÜZELTMEK İÇİN ÜST KOMUTLARI ÇALIŞTIRMANIZ GEREKİR çünkü depolar kapalı sed -i 's/mirrorlist/#mirrorlist/g' /etc/yum.repos.d/CentOS-* sed -i 's|#\s*baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g' /etc/yum.repos.d/CentOS-* curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bash After these commands it worked, thank you
December 11, 2024Dec 11 Hi, I hope you are doing well.whenever i ran this command all things goes as expected well.curl -s -L https://www.alphagnu.com/upload/centos7-repo-fix.sh | bashbut when trying to update the system by:yum update: I getting the bellow error. yum updateLoaded plugins: fastestmirrorLoading mirror speeds from cached hostfile * epel: d2lzkl7pfhq30w.cloudfront.netNo packages marked for updatekindly guide me what is the issuethank you
