hello;
I am using "AlmaLinux release 8.9 (Midnight Oncilla)". I use the "Purge Varnish" plugin on WordPress. but there is no secret file. How can I create this?
I am using cwp pro. web servers: nginx-varnish-apache..
Is there a different way to clear cache?
thank you..
  • 2 months later...
@Sandeep B.
Do you have any ideas about this issue? I am currently using Varnish 6.4.
I use the "purge varnish" plugin on wordpress to clear the cache..
thank you..
On 8/12/2024 at 4:14 PM, Alexander said:
@Sandeep B.
thank you..
to remove cache you can run this command
/usr/bin/varnishadm 'ban req.url ~ .'
