Posted March 5, 20241 yr Hi, I would like to enable PostgreSQL and pgAdmin, I do following this tutorial PostgreSQL Installation and Management - Control WebPanel Wiki (centos-webpanel.com) and enable pgsql module in PHP version switcher, but pgAdmin still can not work The message error is: Your PHP installation does not support PostgreSQL. You need to recompile PHP using the --with-pgsql configure option. Please help! Thanks!
March 5, 20241 yr Have you tried going to PHP Selector or PHP-FPM Selector and using "manage options" Action to add pgsql PostgreSQL driver for PHP for your version of PHP? It is normally not active for default compilations.
March 7, 20241 yr Solution try this : cd /usr/local/cwpsrv/var/services yum install cwpPgphp -y yum reinstall cwpPgphp -y mv phpPgAdmin phpPgAdmin.bak wget https://github.com/phppgadmin/phppgadmin/releases/download/REL_7-13-0/phpPgAdmin-7.13.0.zip unzip phpPgAdmin-7.13.0.zip mv phpPgAdmin-7.13.0 phpPgAdmin rm -rf phpPgAdmin-7.13.0.zip
March 7, 20241 yr Author Thanks Sandeep! 10 hours ago, Sandeep B. said: try this : cd /usr/local/cwpsrv/var/services yum install cwpPgphp -y yum reinstall cwpPgphp -y mv phpPgAdmin phpPgAdmin.bak wget https://github.com/phppgadmin/phppgadmin/releases/download/REL_7-13-0/phpPgAdmin-7.13.0.zip unzip phpPgAdmin-7.13.0.zip mv phpPgAdmin-7.13.0 phpPgAdmin rm -rf phpPgAdmin-7.13.0.zip
August 31, 2024Aug 31 On 3/7/2024 at 12:38 AM, Sandeep B. said: try this : cd /usr/local/cwpsrv/var/services yum install cwpPgphp -y yum reinstall cwpPgphp -y mv phpPgAdmin phpPgAdmin.bak wget https://github.com/phppgadmin/phppgadmin/releases/download/REL_7-13-0/phpPgAdmin-7.13.0.zip unzip phpPgAdmin-7.13.0.zip mv phpPgAdmin-7.13.0 phpPgAdmin rm -rf phpPgAdmin-7.13.0.zip Hello friend, I'm trying to make phpPgAdmin work but it doesn't work, I rebuilt php, I did what you propose here and I still get the following error, any other solution? Your PHP installation does not support the pgsql module. You will need to install, enable, or compile it to use phpPgAdmin.
