Posted June 1, 20231 yr These functions allow you to access Oracle Database. They support SQL and PL/SQL statements. Basic features include transaction control, binding of PHP variables to Oracle placeholders, and support for large object (LOB) types and collections. Oracle’s scalability features such as Database Resident Connection Pooling (DRCP) and result caching are also supported. For el8/Centos 8/stream/Rocky/Almalinux : First download the required Oracle instantclient packages : cd /usr/local/src wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-basic-21.5.0.0.0-1.el8.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-sqlplus-21.5.0.0.0-1.el8.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-devel-21.5.0.0.0-1.el8.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-jdbc-21.5.0.0.0-1.el8.x86_64.rpm Second Installation : cd /usr/local/src dnf localinstall oracle* --nogpgcheck For el7/Centos 7: First download the required Oracle instantclient packages : cd /usr/local/src wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-basic-21.5.0.0.0-1.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-sqlplus-21.5.0.0.0-1.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-devel-21.5.0.0.0-1.x86_64.rpm wget https://download.oracle.com/otn_software/linux/instantclient/215000/oracle-instantclient-jdbc-21.5.0.0.0-1.x86_64.rpm Second Installation : cd /usr/local/src yum localinstall oracle* --nogpgcheck Now install OCI8 php extension : Now you need to install oci8 php extension via below process, please note the versions for oci8 are sensitive with the php version. For php switcher : php 7.x : cd /usr/local/src wget https://pecl.php.net/get/oci8-2.2.0.tgz tar -zxvf oci8-2.2.0.tgz cd oci8-2.2.0 phpize ./configure make && make install php 8.0 (only): cd /usr/local/src wget https://pecl.php.net/get/oci8-3.0.1.tgz tar -zxvf oci8-3.0.1.tgz cd oci8-3.0.1 phpize ./configure make && make install php 8.1/8.2 (only): cd /usr/local/src wget https://pecl.php.net/get/oci8-3.2.1.tgz tar -zxvf oci8-3.2.1.tgz cd oci8-3.2.1 phpize ./configure make && make install Now add this line at the end of this file /usr/local/php/php.ini : extension=oci8.so Now you can check the phpinfo there you can see oci8 is now enabled. For php selector and php-fpm if you need to install oci8 for php 7.4 then replace phpize and ./configure with : **change 74 to 80 for php 8.0 or to 81 for php 8.1/8.2 For php selector 7.4 : /opt/alt/php74/usr/bin/phpize ./configure --with-php-config=/opt/alt/php74/usr/bin/php-conf For php-fpm 7.4: /opt/alt/php-fpm74/usr/bin/phpize ./configure --with-php-config=/opt/alt/php-fpm74/usr/bin/php-config example : cd /usr/local/src wget https://pecl.php.net/get/oci8-2.2.0.tgz tar -zxvf oci8-2.2.0.tgz cd oci8-2.2.0 /opt/alt/php74/usr/bin/phpize ./configure --with-php-config=/opt/alt/php74/usr/bin/php-config make && make install and then add this line in php.ini : extension=oci8.so **restart php-fpm service or stop the php service and start it from cwp php-fpm module.
