Posted January 16, 20241 yr hello guys , hello guys , i watch video about make mx_routing with gsuite, i try everything but i got this message's when try receiving mails : Quote Jan 16 19:45:25 server postfix/smtpd[5300]: connect from mail-wr1-f69.google.com[209.85.221.69] Jan 16 19:45:25 server postfix/smtpd[5300]: TLS SNI server.infolynks.com from mail-wr1-f69.google.com[209.85.221.69] not matched, using default chain Jan 16 19:45:25 server postfix/smtpd[5300]: Anonymous TLS connection established from mail-wr1-f69.google.com[209.85.221.69]: TLSv1.2 with cipher ECDHE-RSA-AES128-GCM-SHA256 (128/128 bits) Jan 16 19:45:25 server cbpolicyd[29837]: module=Quotas, mode=update, host=209.85.221.69, helo=mail-wr1-f69.google.com, from=******@gmail.com, to=it@*****ns.com, reason=quota_update, policy=6, quota=3, limit=4, track=Sender:@gmail.com, counter=MessageCount, quota=5.90/250 (2.4%) Jan 16 19:45:25 server postfix/smtpd[5300]: EC905A00117: client=mail-wr1-f69.google.com[209.85.221.69] Jan 16 19:45:26 server postfix/cleanup[5305]: EC905A00117: message-id= Jan 16 19:45:26 server postfix/qmgr[31855]: EC905A00117: from=, size=18989, nrcpt=1 (queue active) Jan 16 19:45:26 server postfix/smtpd[5300]: disconnect from mail-wr1-f69.google.com[209.85.221.69] ehlo=2 starttls=1 mail=1 rcpt=1 bdat=1 quit=1 commands=7 Jan 16 19:45:40 server postfix/smtp[5307]: ECCFFA00117: to=, relay=127.0.0.1[127.0.0.1]:10024, delay=0.85, delays=0.12/0/0.01/0.72, dsn=5.4.0, status=bounced (host 127.0.0.1[127.0.0.1] said: 554 5.4.0 id=17023-09 - Rejected by next-hop MTA on relaying, from MTA(smtp:[127.0.0.1]:10025): 554 5.4.0 Error: too many hops (in reply to end of DATA command)) Jan 16 19:45:40 server postfix/cleanup[5305]: DE484A008E5: message-id= Jan 16 19:45:40 server postfix/bounce[5364]: ECCFFA00117: sender non-delivery notification: DE484A008E5 Jan 16 19:45:40 server postfix/qmgr[31855]: DE484A008E5: from=, size=38401, nrcpt=1 (queue active) Jan 16 19:45:40 server postfix/qmgr[31855]: ECCFFA00117: removed Jan 16 19:45:41 server postfix/smtp[5313]: DE484A008E5: to=, relay=gmail-smtp-in.l.google.com[74.125.71.26]:25, delay=0.58, delays=0.03/0.03/0.2/0.33, dsn=5.7.1, status=bounced (host gmail-smtp-in.l.google.com[74.125.71.26] said: 550-5.7.1 [161.97.134.204 12] Gmail has detected that this message is 550-5.7.1 likely unsolicited mail. To reduce the amount of spam sent to Gmail, 550-5.7.1 this message has been blocked. For more information, go to 550 5.7.1 https://support.google.com/mail/?p=UnsolicitedMessageError x22-20020a05600c421600b0040e4f22c9b3si6053079wmh.198 - gsmtp (in reply to end of DATA command)) Jan 16 19:45:41 server postfix/qmgr[31855]: DE484A008E5: removed and from gmail : 554 5.4.0 Error: too many hopse
January 16, 20241 yr Author main.cf : # postfix config file # uncomment for debugging if needed #soft_bounce=yes # postfix main mail_owner = postfix setgid_group = postdrop delay_warning_time = 4 smtp_address_preference = ipv4 # postfix paths html_directory = no command_directory = /usr/sbin daemon_directory = /usr/libexec/postfix queue_directory = /var/spool/postfix sendmail_path = /usr/sbin/sendmail.postfix newaliases_path = /usr/bin/newaliases.postfix mailq_path = /usr/bin/mailq.postfix manpage_directory = /usr/share/man # network settings inet_interfaces = all mydomain = server.infolynks.com myhostname = server.infolynks.com mynetworks = $config_directory/mynetworks mydestination = $myhostname, localhost.$mydomain, localhost relay_domains = proxy:mysql:/etc/postfix/mysql-relay_domains_maps.cf # mail delivery recipient_delimiter = + # mappings alias_maps = hash:/etc/aliases alias_database = hash:/etc/aliases transport_maps = hash:/etc/postfix/transport #local_recipient_maps = # virtual setup virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_alias_default_maps.cf, proxy:mysql:/etc/postfix/mysql-virtual_alias_maps.cf, regexp:/etc/postfix/virtual_regexp virtual_mailbox_base = /var/vmail virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains_maps.cf virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_maps.cf, proxy:mysql:/etc/postfix/mysql-virtual_alias_pipe_maps.cf virtual_minimum_uid = 101 #virtual_uid_maps = static:101 #virtual_gid_maps = static:12 #virtual_transport = dovecot virtual_uid_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_uid_maps.cf virtual_gid_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_gid_maps.cf virtual_transport = lmtp:unix:private/dovecot-lmtp dovecot_destination_recipient_limit = 1 # debugging debug_peer_level = 2 debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin xxgdb $daemon_directory/$process_name $process_id & sleep 5 # authentication smtpd_sasl_auth_enable = yes smtpd_sasl_security_options = noanonymous smtpd_sasl_local_domain = $myhostname #broken_sasl_auth_clients = yes smtpd_sasl_type = dovecot smtpd_sasl_path = private/auth # tls config smtp_use_tls = yes smtpd_use_tls = yes smtpd_tls_security_level = may smtpd_tls_loglevel = 1 smtpd_tls_received_header = yes smtpd_tls_session_cache_timeout = 3600s tls_random_source = dev:/dev/urandom smtp_tls_session_cache_database = btree:$data_directory/smtp_tls_session_cache # Change mail.example.com.* to your host name smtpd_tls_key_file = /etc/pki/tls/private/hostname.key smtpd_tls_cert_file = /etc/pki/tls/certs/hostname.bundle # rules restrictions smtpd_client_restrictions = smtpd_helo_restrictions = smtpd_sender_restrictions = check_sender_access hash:/etc/postfix/sender_whitelist, check_sender_access hash:/etc/postfix/sender_blacklist smtpd_recipient_restrictions = check_policy_service inet:127.0.0.1:10031, permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_sender, reject_non_fqdn_recipient, reject_unknown_recipient_domain, reject_rbl_client bl.spamcop.net smtpd_helo_required = yes unknown_local_recipient_reject_code = 550 disable_vrfy_command = yes smtpd_data_restrictions = reject_unauth_pipelining # Other options # email size limit ~20Meg message_size_limit = 204800000 mailbox_size_limit = 2048000000 # Limit 500 emails per hour per email address anvil_rate_time_unit = 3600s smtpd_client_message_rate_limit = 500 # Vacation Scripts vacation_destination_recipient_limit = 1 recipient_bcc_maps = proxy:mysql:/etc/postfix/mysql-virtual_vacation.cf smtpd_milters = inet:127.0.0.1:8891 non_smtpd_milters = $smtpd_milters milter_default_action = accept milter_protocol = 2 tls_server_sni_maps = hash:/etc/postfix/vmail_ssl.map
January 18, 20241 yr Hi in mail routing you need to change to remote for the domain. you can do it from cwp admin search for routing
January 20, 20241 yr Author On 1/18/2024 at 9:00 PM, Sandeep B. said: Hi in mail routing you need to change to remote for the domain. Tou can do it from cwp admin search for routing i already do that , this error after change form local to remote
January 20, 20241 yr Author 35 minutes ago, Sandeep B. said: please check the /var/log/maillog and check what you see there same logs i post in first, but when i switch back from remote to local there no problem , but i cant send mails from same domain cwp to suite, postfix , all default without any changes from cwp
January 20, 20241 yr Author 14 minutes ago, Sandeep B. said: The error indicates that it was blocked for spaming issue. spam becz loop inside server !? like i said this problem only appear when change mail server from local to remote , i think no one test this from cwp team ? or becz postfix is old version with bugs ? anyone try gsuite > cwp same domain split ! any solution or advice as to what is causing this? or where do I start?
January 20, 20241 yr hi, the cwp postfix is a modified version and there is no issue with it. also, scan your websites for malware as the spamming issue usually comes with it.
January 21, 20241 yr Author 3 hours ago, Sandeep B. said: hi, the cwp postfix is a modified version and there is no issue with it. also, scan your websites for malware as the spamming issue usually comes with it. im sure its from postfix some settings missed , its clean server with cwp , i changed dns -and mailserver from local to remote i missed something ? and i got replay with error "554 5.4.0 Error: too many hopse"
January 21, 20241 yr to investigate more about this error you need to check all the alias forwarders and check if the same email is not set for the alias.
January 23, 20241 yr Author can i offer some money to fix this problem? and check the best settings for postfix on my vps
