June 2, 20233 yr In this tutorial we’ll learn how you can install CXS in CWP -Control Web Panel wiht below simple steps. CSX is paid Program and you need license to install and use it : ConfigServer eXploit Scanner (cxs) is a server malware, exploit and antivirus scanner that performs active scanning of files as they are uploaded to the server For dedicated or virtual servers – protects all domains, IP addresses and users on the server Active (realtime), manual, and scheduled scanning can be performed Scans for suspected exploits, viruses, suspicious resources Quarantine or delete suspicious files Provides an easy to use interface within the root or admin control panel. Licensed on a per server basis, no limit on users or accounts. One time purchase price, includes software updates for the life of the product. No monthly fees. Buy the license here : LINK Install CXS in CWP steps : STEP 1 : cd /usr/src yum install sqlite perl-DBI perl-DBD-SQLite perl-Linux-Inotify2 -y rm -f cxs* wget https://download.configserver.com/cxsinstaller.tgz tar -xzf cxsinstaller.tgz chattr -i -R /usr/local/cwpsrv/htdocs/admin/ perl cxsinstaller.pl 1.1.1.1 rm -fv cxsinstaller.* ** replace the 1.1.1.1 with your licensed server IP STEP 2 : Now got wo cwp admin dashboard and navigate : CWP.admin > Configserver Scripts >> ConfigServer Exploit Scanner >> cxs Command Wizard Choose all default settings and save it after run this command to use custom CLAM AV : sed -i '$ a clamdsock=/var/run/clamd.amavisd/clamd.sock' /etc/cxs/cxs.defaults Then Restart CXS service : service cxswatch restart STEP 3 : Make Directory Permission to 755 : in order to scanner to work you need to change the DIRECORY permission to 755, to do this all at once for all users run the below command: chmod 755 /home/*/public_html If you’ve domain/subdomains directory outside of public_html run below command to fix permission : chmod 755 /home/*/* Also you can create custom cron job to run every 15 minutes to fix the permission for new added users or domain/subdomain Add this cron job : */15 * * * * /usr/bin/chmod 755 /home/*/*
April 6, 20242 yr Wow , first time to know that cxs is not working on half of my servers !!!!! Just tested it with fake virus and if the permissions is not 755 cxs is just not working !. Thank you man for this great tip. But I'm afraid that running chmod 755 /home/*/* will break some functions for my users ? I guess it's much safer approach to run this instead ? find /home/*/ -maxdepth 1 -type d -exec chmod 755 {} \; let me know what do you think ?
April 7, 20242 yr I ended up using cwp api to fix the permissions. Much safer and low footprint on the cpu / rams. I created 2 scripts to accomplish the task for all users on the server. Here is a one line command to create the 2 scripts along with required permissions and code. echo -e '#!/bin/bash\n\n# Path to the script that lists the usernames\nUSERS_SCRIPT="/root/myscripts/list_users_only"\n\n# CWP API command to fix permissions for a user\nFIX_PERMS_COMMAND="/scripts/cwp_api account fix_perms"\n\n# Loop through each username and fix permissions\nwhile read -r username; do\n echo "Fixing permissions for user: $username"\n $FIX_PERMS_COMMAND $username\ndone < <($USERS_SCRIPT)\n\necho "Permissions fixed for all users"' > fix_permissions_allusers.sh && echo -e '#!/bin/sh\n#\n##################################\n# CentOS Web Panel SCRIPT'\''s\n###################################\n\nmysql root_cwp -B -N -s -e "SELECT username FROM user" | while read -r line\ndo\n echo "$line"\ndone' > list_users_only && chmod +x fix_permissions_allusers.sh list_users_only Don't forget to create the folder myscripts first. mkdir /root/myscripts && cd /root/myscripts then fire the one line command I shared to create the scripts. You can simply run it using : ./fix_permissions_allusers.sh or create cron every hour 10 * * * * /root/myscripts/fix_permissions_allusers.sh
