I've noticed a very large log file into /usr/local/cwp/php71/var/log/php-fpm.log Does anyone knows how to setup a logrotate entry to keep that log and others on that folder under control?
Thanks in advance!
Edited by Fidolas
Solved by Sandeep B.
Go to solution
  • Solution
Thanks in advance!
You can use this tutorial to clear the logs via cron job :
or you can use below configs for logrotate :
yum install logrotate -y
create the cwp logrotate config file :
nano /etc/logrotate.d/cwplog
add this lines to it and save :
/usr/local/cwp/php71/var/log/*.log
/var/log/cwp/*.log
    daily
    rotate 3
    size 15M
    compress
    dateext
    dateformat -%d-%m-%Y
    delaycompress
you can debug/dry-run the log rotate config via this command :
logrotate -d /etc/logrotate.d/cwplog
disable system protect for logrotate :
sed -i '/ProtectSystem=full/s/^/#/g' /usr/lib/systemd/system/logrotate.service
systemctl daemon-reload
and restart logrotate.timer and logrotate via systemctl :
systemctl restart logrotate.timer logrotate
check logrotate.timer and logrotate are running via this command :
** logrotate will show inactive other than that ensure the service doesn't have any error
systemctl status logrotate.timer logrotate
Thanks a lot, sir. Very detailed and easy to follow answer.
Cheers 🙂
  • 1 month later...
HI, thank you very much dear Sandeep for you nice comprehensive answer
just I would to ask about this line:
incase using php 8.1 instead of the php 7.1, it's nee to change: /usr/local/cwp/php81/var/log/*.log  or it's not necessary
thanks
HI, when I run the the above command, getting the below error:
[root@cloud ~]# systemctl restart logrotate.timer logrotate
Failed to restart logrotate.timer: Unit not found.
Failed to restart logrotate.service: Unit not found.
[root@cloud ~]# systemctl status logrotate.timer logrotate
Unit logrotate.timer could not be found.
Unit logrotate.service could not be found.
please guide me
thanks.
thanks
CWP only uses PHP 7.1 and not 8.1. You can use any PHP version you want on your server but CWP will use always the 7.1 version.
