Hi Guys!
Trying to find info, I got here! and I've seen plenty of very interesting things!!
I hope anyone can help me out..
I have a server with Centos 7.9 and CWP..
problem is, after a penetration test, they say that a critical issue showed up.. and need to be fixed
CVE-2022-2068..
I have OpenSSL 1.0.2k-fips  26 Jan 2017 in the system. (this is what openssl version shows)
but in php it shows..
OpenSSL Library Version OpenSSL 1.0.1e-fips 11 Feb 2013
OpenSSL Header Version OpenSSL 1.0.1e-fips 11 Feb 2013
Anyway..
I found a way to update openssl in the system.. on the CWP forum.. I followed this.. https://forum.centos-webpanel.com/index.php?topic=4441.0
yum install install gcc gcc-c++ pcre-devel zlib-devel make unzip gd-devel perl-ExtUtils-Embed libxslt-devel openssl-devel perl-Test-Simple
yum groupinstall 'Development Tools'
cd /usr/src
wget https://www.openssl.org/source/old/1.1.1/openssl-1.1.1v.tar.gz
tar xvf openssl-1.1.1v.tar.gz
mv openssl-1.1.1v openssl
cd openssl
./config --prefix=/usr/local/openssl --openssldir=/usr/local/openssl --libdir=/lib64 shared zlib-dynamic
make -j4
make test
make install
mv /usr/bin/openssl /usr/bin/openssl-backup
ln -s /usr/local/openssl/bin/openssl /usr/bin/openssl
Rebuild apache.
now If I do openssl version It shows
it shows
_SERVER["SERVER_SOFTWARE"] Apache/2.4.57 (Unix) OpenSSL/1.1.1v
SERVER_SOFTWARE Apache/2.4.57 (Unix) OpenSSL/1.1.1v
But the php openssl remains..
I think I have to recompile php.. I did once but everything remains.. the same version.. 😞
I think I'll have to do it manually but I have the feeling I can end up breaking things in CWP..
Is there a way to update the php libraries without breaking cwp?
thank all of you for reading and special thanks to those who can help me out!
Edited by CyberFred
Solved by CyberFred
Go to solution
centos/el uses backporting for security fixes the version will show old but the security vulnerability is already fixed via yum update
also centos 7 is ending in few months consider upgrading to almalinux8/centos 8 stream
and it is not recommended to update the openssl in centos/el OS because this will break many dependencies.
to upgrade apache webserver openssl you can use this tutorial
6 hours ago, Sandeep B. said:
i always preferer stream OS and alma is better than rocky
Thanks Sandeep I was leaning towards rockybut if you consider alma better, then I should consider that..
